how to bleed the air from Hyd. steering
I had to repair a leak on a hyd. steering fitting and now my steering has air in it. Its like a dead spot that the motor can go either way on its own. I am sure its air in the system because it wasnt doing it before I fixed the leak. Now how do you bleed the system? There are black caps on the fittings on each side but so far I have not been able to get the caps off. I assume there are some kind of shrader/bleeder valves under the caps. Thanks Johnny
Home Forums Bass Cat Boats how to bleed the air from Hyd. steering
