Johnson/Mayfair pump-out pump replacement procedure??
OK, the lower of the two pumps pictured developed a crack at the hose nipple and the pump case needs to be replaced.Couple of questions/assumptions:1) Need an in-line replacement Johnson pump, 1000 or 750, doesnt matter?2) The existing hose should fit over the new Johnson pump nipple? (same OD-ID dimension as the older Mayfair pump hose nipple?)3) To remove the existing pump housing, which is siliconed to the wall of the livewell, use a razor blade or exacto knife and carefully carve out old pump? 4) Type of silicone to use?5) Whats the trick to hold the newly siliconed pump in place while the silicone cures?6) Trim the threaded base of the new Johnson pump to fit within the plastic screen?Thanks in advance for sharing your insight / experience!
Home Forums Bass Cat Boats Johnson/Mayfair pump-out pump replacement procedure??
