Leaking fuel tank
Has anyone had problems with their fuel tanks leaking at the supply fitting on the tank? My boat is a 2014 Puma FTD with the dual 26 gal tanks, When I first got the boat the left tank started seeping. Contacted Richard at BCB and he said get it to the dealer. I took it to the dealer 2 1/2 hours away each direction. They hadnt seen this before, put some kind of sealer at the fitting, didnt really solve the problem still seeped. I took it apart and put a very good sealer under the nut and it seemed to fix it for a while, now its leaking again. I think there is something flawed with the tank internally at the supply fitting. Of course now Im out of warranty with BCB. Im thinking now to see how much a tank costs and replace it before I have a fire. And to add I dont overfill the tank when gassing the boat. Im real curious if Im the only one with this problem or if its a little more widespread? Not to disparage my dealer, just not interested is pursuing the dealer option, it took four trips to get the ProXS leaking oil pump fixed. Heres a pix, Thanks, Dave
Home Forums Bass Cat Boats Leaking fuel tank
Viewing 13 posts - 1 through 13 (of 13 total)
