I have a light that isnt coming on all of the time in one of the rod lockers. Is it triggered by a switch or is it just a sensor? I looked for a switch but didnt see one. Boat is a 2017 Eyra, thanks.
Minne is a 99 model , and they may have changed since then , but mine are mercury switches . — when they dont come on I just ” BUMP ” the lid and they come on . — Hoss
The 17 should have the new stainless compression switch. Check wiring on the back of switch. Possible wire came off. These are neat switches. Not much to go wrong as far as the switch goes2013 PANTERA 2MERCURY 200 PRO XSMINNKOTA 80LB FORTREX25 fury
They are a post switch that sometimes sticks. Just locate the post amd manually push it into lossen it. I might try and add some machine oil to the post for better lubrication as mine stick too.
Speck I added a light in my glove box. I used one of these neat little switches. Ive had no trouble with mine. Though your info is good to kno.2013 PANTERA 2MERCURY 200 PRO XSMINNKOTA 80LB FORTREX25 fury
BCB on my 17 Jag I have 2-3 different boxes where they seem to stick because lights dont come on. If I manually depress it and release the pst the lights will come on. Is this more of a bad switch than it feels like they are sticking when deprssing and releasing them.
They put petroleum jelly on for a corrosion guard after install. It could be the corrosion guard is attracting dirt and thus the machine oil loosening it.
