livewell control valve
On a 96 PII. I have the livewell control valve that has a push pull cable at the console. With it closed it keeps water from flowing into the livewells but it allows it to drain out. I assume I need to replace the control valve to fix this. How do you remove the valve from the boat. When I looked it seems to actually have a bracket that goes to a pump as well. It is hard to tell how to remove it. I assume it has some screws holding it in place?
Home Forums Bass Cat Boats livewell control valve
