My 2022 Puma STS has a livewell issue. I have the overflow plugged but after I make a run my livewells are about 50% empty. I do not have any water in the bilge and the it doesn’t leak on the trailer at weigh-in. All I can figure is that the boat is sucking the water out past the ball valve when I run on plane, does that make sense? This problem showed up early so I don’t think it is debris in the valve. I know I could replace the ball valve but that looks to be a pain to get to so I want to make sure that is the problem. Do I just need to make an adjustment to the toggle switch? Thanks for the help.
