Loose Fender question
I have a 2012 trailer with tandem fiberglass fenders. The front of 1 fender keeps braking loose from the support bracket. I used the black sealant BC was kind enough to provide then c-clamped it but within a trip or 2 it is loos again. Has anyone found a way to bolt the fender down for a permanent fix and then reinstall the step pad. Since you are bolting fibergall to metal I would think you need a good sized washer but the head of the bolt will stick up thru the step pad material. Someone suggested using a jack to put the weight of the boat on the support bracket until it bends closer to the fender. For obvious reasons doing it this way makes me a bit nervous at to making a bad situation even worse. It does seem the fender was installed a bit twisted causing the problem. Thanks.
Home Forums Bass Cat Boats Loose Fender question
