Mine was set up with a in line fuse holder, and this issue drove me crazy sometime it wouldnt even turn back on then two minutes later hit the button and on it would come. The spring in the fuse holder was not applying enough pressure against the fuse and when bouncing around would shut the unit down next the pressure was light enough that sometime when you went to turn it on the amps were to high for the connection and it wouldnt come on this has happened twice in 4 yrs with two different units, I finally just hardwired the thing and through the fuse holder away. What a pain to be in a Tourney and have the thing not come on for several minutes once you stop, push the button, no, try again in a minute or so and on an on.
