BCB - I ordered a single balzout mount from the parts store and would like to through bolt it. To do so I will have to drill an access hole under the Fortrex foot pedal. BCB owner Steve Schmidt sent me pics of his 09 Puma and I plan on doing the same using a 6 inch Sea Flo hatch - https://www.amazon.com/SEA-FLO-Circular-Inspection-Detachable/dp/B07PFL72GS?ref_=ast_sto_dp&th=1
I have a 2010 Puma. Is there anything I need to be concerned with or aware of before I install the hatch Any insight into the proper install if the balzout mount is appreciated too. Thank you.
You should be able to drill through that area under the recessed pedal with some caution. There is nothing there short of some wiring and the drain guidance into the V from the recess drains. Tuck your wiring out of the way before you drill.
I fit perfectly between the feet of the trolling motor and I was able to access the area needed to secure the balzout mount. It turned out great and I am very happy with it.
Chris – I didn’t take any pics during the install but I centered the hole where none of the trolling motor pedal feet would be touching it. It really worked out well.
