Master power switch/power pole voltage issue
I have a new to me 2017 Eyra. I had the dealer install 2 Garmin 126’s at the console and 2 at the bow. From what I can tell, the only thing connected to the master power switch in the bilge is the power poles. When attempting to deploy the power poles, the port side deploys fine, the starboard side deploys a few inches, pauses, deploys a few more inches, pauses. During deployment, one of my graphs starts dropping voltage. It reads around 12.6 then decreases to 9v while the power poles are being deployed. It appears the pp wires run directly to my brand new cranking battery. All other graphs read 13+ volts and are not affected. I looked at the switch and the bottom two spades are 1. Power wire from the battery and 2. Red wires from the power poles. The confusing part is a grey wire connected to the top spade connection. I contacted power pole support and they requested I purchase a new circuit board for the starboard pump. So I did and the problem persists. I also changed the fluid; no help. Obviously it’s a wiring issue somewhere but have no clue where to look. Any suggestions as to where to begin? I attached a pic of the switch.
Home Forums Bass Cat Boats Master power switch/power pole voltage issue
