Minn Kota MK440PC Charger Question
I have a question regarding a new Minn  Kota MK 440 charger I recently purchased from the BassCat store. I hooked the charger up to all (4) batteries respectively. I have (3) Deka lead acid batteries for my trolling motor and a Northstar 31AGM to crank the Mercury 250 ProXS. I programmed the appropriate “battery profile” into each bank, choosing bank 1 for the AGM, and banks 2-4 for the lead acid batteries. I’m having a great deal of doubt regarding this chargers performance with an AGM battery. I had the batteries fully charged with my old charger, which I verified with a volt meter. When I plugged in the Minn Kota Charger, banks 2-4 registered 75% charged and within 30min registered fully charged. The AGM at bank 1 on the other hand only  registered 25% charged. I immediately rechecked with the volt meter only to find that it registered fully charged. It took (5) hours on the Minn Kota Charger to achieve 100% charge.   i started getting skeptical about the overall condition of my North Star battery. I took It this morning and had it load tested and was told that the battery is as good as new.   i came home and put the battery in the boat this morning. This time I moved the charger terminal leads from bank #2 to bank #1, and bank #1 to bank # 2. I plugged the charger in and reprofiled the batteries so that bank #2 would read AGM, and bank #1 would read flooded. The problem now shows up on bank #2 which is connected to the AGM battery. It’s showing that the AGM battery is only 25% charged, but when I had it load tested and checked 30min. prior, it showed FULLY CHARGED!   Has anyone else experienced similar problems with this charger and AGM batteries?
Home Forums Bass Cat Boats Minn Kota MK440PC Charger Question
