It will be this weekend before I can try it, but:I believe that the interferrence is electro-magnetic comming directly from the motor case to the transducer. All of the filters, ground wires and chokes will not protect from this instance. In the aircraft industry, we have something called mu metal, it is a highly permable metal used for protection from magnetic interferrence. If one were to take some ferrus metal (a magnet sticks to it) and place it between the motor case and the transducer, the magnetic pulses from the motor should be shunted through the metal and circulate within the metal and not make it to the transducer. Perhaps something as simple as a steel soup can would work.Might be worth a tryjwt
