Ok an update, went out to check some things, this time nothing works but the horn on the Vision touch pad. So it looked under the dash and noticed the touch pad has a ribbon wire coming out and then goes to some other type of electrical component, so it it did not come undone. When I got back up, there was power to the switch again. So I wiggled the ribbon wire and low and behold things started to work. My question is if I pull out the vision touch pad, is the ribbon wire on a plug or is it hard wired to the touch pad. If it is on a plug of some kind could I just put some dialectic grease on it. But if it is hard wired I guess I need a new switch. Thanks again
