Need help!!!
Got Pantera III a month ago. 2001 Opti 200hp. First time on water after high pressure booster pump replaced, boat on plane faster than any of 10 bass boats I've had, ran great. Previous owner had a Stingray Stealth hydrofoil on, prop is 25" Tempest plus with 1 vent open and 2 with large plugs and pad down to center prop shaft was 4". Planing almost instant! RPM's per gauge got to only 5290 during day. I didn't like hydrofoil so removed it, removed the 2 large plugs so now all 3 vent holes open and raised prop shaft to 3 1/4" below pad. Took rig out yesterday and impossible to get on plane! Even had my partner plus a couple heavy fishing bags up front and would not break over. Saw 5700 rpm's before shutting down but did not even seem like it was going to plane - prop blow out and no way was boat going to plane, tried several times then idled rest of time out. Now considering reversing back to original. Cannot tell speed when I first took it out and got on plane instantly as speedo not working, nor GPS on graph. Obviously no speed yesterday. Shouldn't have to have foil on, to me prop was too low when I got it? I had 25" tempest + on 02 Classic and was very good, this boat little heavier but shouldn't stop from planing at all! Anyone have any ideas before I put it back the way it was?
Home Forums Bass Cat Boats Need help!!!
Viewing 5 posts - 31 through 35 (of 35 total)
