Need Help! Access hatch under TM as an option?
Has anyone installed an access hatch/plate under their trolling motor foot pedal "after market?" I know on some models with factory installed RAM mounts in the bow recess, BCB will cut an access hatch and cover it with the same plate for passenger consoles (BCB-please correct me if this is wrong).Trying to get an idea of the diameter of the hole, the diameter of the cover, best way to cut and how hard of an install this would be.Reason I ask, I was helping a fellow member install a 958 and RAM on his 2010 P II. Opted bolt through vs screw in option. Read several posts on here how other members were able to access through starboard rod locker to put fender washers and nylock nuts. Sounded and looked easy enough from the great posts and pictures.... Well, let me tell you...there is a lot less room in the rod locker and clearance below the deck and recess in a P II compared to a Puma/Cougar (which was what most of the posts cited). We were able to get 2 ea 5/16-18x2 bolts with washers/nuts on after much contortion, extensions, and effort, but cannot get to the 3d due to slight bend and lack of space and no visual! Even had my daughter try and crawl up there, but think we need an infant to fit . May buy a cheap endoscope just so I can see what we are trying to do.Considering adding the access under TM if not too difficult and will allow for future "re-tightening" if needed. Thanks in advance!Last edited by HSVBCB on March 4th, 2013, 7:03 pm, edited 1 time in total.
Home Forums Bass Cat Boats Need Help! Access hatch under TM as an option?
