New gas line increases speed
After noticing I had the old mercury fuel line(red writing on it/ethanol unfriendly), I replaced them from the selector switch to the motor. I cut up the old line into small pieces to examine and was shocked what I found. The inner liner not only had completely separated from the hose, but was rock hard in several places and cracked to pieces. Luckily my ad-on water/fuel separator was catching these bits of debris before they wound up going thru the engine. Now heres the weird thing. Ive had no issues with the motor running or idling with the old fuel line except for the fact that the boat wasnt as fast on top end as I thought it should be. I have a 00 Sabre with a 00 175 efi. I was running 64.7 turning a new tempest plus 25 in perfect condition at 6000 rs, 1/2-1/4 tanks gas, all tackle and me(190 pds) and motor set at about 3.6" below pad. Since the new fuel line has been installed, I ran it one day and hit 68.7 @ 6,000 rs and another day hit 69.4 at 6025 rs. All these speeds are gps too by the way, although my tach and psi are analog. I realized that the old line could have restricted the fuel flow and that could have been slowing me down, but the wierd thing is that it didnt affect my rpms before. Im finally satisfied with my setup. My top end speed at 69.4 works out exactly to 9% slippage on the performance calculator with 1.87 gears. It feels nice knowing that my 11 year old Merc can still do what it should do new!!Last edited by arkriverrat on February 22nd, 2011, 3:34 pm, edited 1 time in total.
Home Forums Bass Cat Boats New gas line increases speed
