Newer Style MG Tour Transducer Connecter
I dont use my graph in such a way that HD and side imaging are hugely useful to me. I mostly want to see the depth, amount of grass and the occassional rock or tree. My old Garmin 178C does an adequate job of that. So much so that I have a couple of them. One on The Black Cat and one on The Tin Can. I recently picked up a new MG Tour Edition with built in transducer for The Black Cat. I just assumed I could keep using my 178C because I had a MG tour with transducer in the past and I have an adapter cable. I was wrong. The connector on the new trolling motor is different. I called Motorguide and was told that they dont make a cable for my unit because Garmin makes one. I called Garmin and the guy I talked to said they dont have a cable that will work, but they have two adapter cables that when paired together "might" work. There is also an old MG part number that might work. Its not 100% clear though if its for the old MG connector or the new one. They say 7 pin, but the MG connector on my TM only has 6 pins (it does have a spot for a 7th). The pictures of the cable show a male connector and the MG trolling motor has a male connector. I dont know if that picture is a marketing mistake, but some vendors still have the old cable in stock. I tried calling Motorguide again, but they didnt seem interested in helping with a discontinued part at all. Just repeated that they do not have an adapter cable for my graph available. I hate to retire my 178c (also GPS map), because I have lots of useful way points stored on it, but I may be looking for a new graph. I really am not looking for anything fancier than my old 178C. I like it. It works for me. I was just wondering if there was anyway to find out which units currently out there are directly plug-in compatible with the new MG connector. There isnt a dealer around here where I can just go look. Bob La Londehttp://www.cncmolds.com--Bob La Londe Forums, Free Lures, Product Reviewswww.YumaBassMan.com CNC Molds N Stuffwww.CNCMOLDS.com
Home Forums Bass Cat Boats Newer Style MG Tour Transducer Connecter
