Never got around to posting the question but now getting prepped for the season and had this on my list to look into…2012 PII/200 Pro XS with Nexsys Gauges –
Last summer, on multiple occasions, upon starting the motor, the gauges (tach, speedo) would cycle over but then not come “online” (i.e. no tach measuring 700 rpm at idle, no H20 pressure, etc.). In the digital readout it would show a flashing icon of what appears to be 2 disconnected wires or an “X” or something (I don’t recall exactly what the icon looks like) and I believe I recall it also saying “No Data” or a bunch of “??????”. So, basically when this happens I have no digital gauge readings at all (i.e. fuel level, engine temp, H20 pressure, rpm, hours etc.). When this has happened I’ve simply turned the key off and then restarted the engine, the gauges cycle over and then everything comes back online good as new with all data being reflected. Humminbird in dash is on. Engine cranks fine, nothing to suggest a battery issue, etc. Saw one other post here where a guy mentioned something similar where when he cranks up the gauges do not boot correctly, and he basically shut down and re-start and the gauges always come back up correctly.
Does anyone else have a similar experience and are there any suggestions on what to look at (loose connection somewhere, setting on dash humminbird, etc.) to figure out why this is happening?
Thanks in advance for any suggestions!
