No Power at Master Power Switch?
BCB Family,06 Pantera ClassicI was hoping you might provide me with some insight. I dont have any power at the master power switch or livewell in or out. However, I do have bilge and horn on the a10 panel (nothing else). Through my research I have found that the terminal block and 20amp breaker are the usual culprits and I have replaced all connections there, cleaned the block, and replaced the breaker. Per other discussion posts, I know that the bilge and horn power supply is directly from the battery and the rest (acc, aerator, recirc, etc.) is through the master power switch, so there must be a missing link (connection) somewhere between the terminal block and the master power switch, correct?All fuses are good - checked and rechecked. That being said, what do you experts think? What should I do?Thanks in advance for your help!
Home Forums Bass Cat Boats No Power at Master Power Switch?
