OK BCB & Others–This is my setup Recommend High 5
1994 Pantera II with 1994 200 EFI Mercury: 1. Laying a straight edge flat against the bottom pad,with contour of boat, the center of my nose cone is 3 1/4-3 1/2 below the pad. 2. 3 of the 8 intake holes on each side of lower unit is plugged with allen screws. 3. At WOT and trimmed out I am reading between 5900 & 6000 rpm & have 12-13 psi on guage. 4. 68-70 mph 5. 48-825872 24P Tempest Plus prop......Is this a small or large hub? 6. 1800'-2000' above sea level.. I would like to have less steering torque & smooth ride at 55-60 mph...and jump out of hole without having to trim up & down all the time....I am also concerned about water pressure..12-13 psi doesn't sound right.... What do I need to do???...Lower motor,change prop,unplug holes & etc...???? Any help will really be appreciated & remember at 66 years old I'm not like Tom Cruise in the movie Top Gun. I DON"T have a need for speed!!!!!! I'll leave that to you young folks.
Home Forums Bass Cat Faq Archive OK BCB & Others–This is my setup Recommend High 5
Viewing 11 posts - 1 through 11 (of 11 total)
