P lll Front Drain Hole
On the the P lll's there are two drain holes in the bow pocket (foot pedal well). The hole in the front has a piece of clear tubing with clear silicone holding it in place. The hole under the foot control does not. Was this tube added by a previous owner or was this a factory installed tubing? I was going to remove it because its clogged with some nasty looking stuff. I just want to make sure it doesn't have a purpose before removing it. Thanks, Ray
Home Forums Bass Cat Boats P lll Front Drain Hole
