PANTERA 3 ENGINE HEIGHT OFF PAD
Ive read several posts regarding engine height.On this particluar hull ive seen it range from 2 to 3-1/2" below pad.I have tried two different props.A 25p trophy and a 25p tempest.The trophy is a good all around prop,good bow lift,neutral steering with little steering torque,however the holeshot is sluggish.The tempest is better out of the hole has great speed but will blow out in rough choppy water if you come off plane and then try to power back up.Its a 2000 p3 with a 2000/200hp optimax.6"manual power lift jackplate.Trying to get an idea of what might be the best all around set up for this rig.Any help would be appreciated.
Home Forums Bass Cat Boats PANTERA 3 ENGINE HEIGHT OFF PAD
