Perko and Southco Latches ~ LONG
Gents (and Ladies), First we realize that all involved apparently like their boats very much. You were all very plain on that. Though we do understand the predicament mentioned on latches. There is and has been a great deal of discussion about the latches. A similar discussion was had when we went from D ring Perko to black T handles and from black T handles to Chrome metallic ones. And we do still use Perko Latches on all Advantage and Vision models. They would be great on those products, though the cost of them would tremendously increase the materials cost on those models. These latches are expensive, the $45 Christmas Special has them at fundamental cost of the latches. Yes they are high! And we will say that again a few times. We have played with latches going back to the 90s and Sarasota latches. Things have come a long ways from those hasps of the 70s. The 2015 era will probably be no different as something different will emerge and the higher price of a Southco now will allow for some improved R & D and costs. When you see a $30k, $40 or a $50,000 boat, we see a trolling motor of about $1k, electronics that now range into the $3k mark, engines that run up to about $18k, propellers of $450 or more, then the trailers and even more parts, and freight to and from. Then we still have to recover our buildings, overheads, insurances, labor, maintenance and then try to make a profit on assembly of those parts. Not to mention that a dealership must also profit on the sale to remain in business. This is not a $50k BCB profit potential. And it is compacted ever so much more in todays climate. It is not all gravy! Do the math on the parts and you will quickly become aware of the limited potential here for any company. We did not offer the Southco latches in 2008, and we do not offer an upgrade. The reason for an upgrade on the black T handle Perko latches to the Chrome metal T handle latches was that we found those to be substandard. We definitely wanted to pitch in our portion. This present Christmas special is an effort to make the latches more affordable for all. They are very, very expensive for a door part, and that we have said many times before. One of the issues is that we use a seal trim on the lips to reduce moisture leakage. This requires that we compress our lids to the seal trim, much like the door trim on your car. Though we do not have the luxury of the volumes that the car industry has. The door pillar holds a pin for the latch hook to rotate against. A neat latching set up which we wish we could modify. We have tried and have even cooperated with a Chinese vehicle parts company and failed to develop one that we preferred. There was a language barrier there on the process. You wont see us getting away from the pressure on the lids as the seal on the lid is crucial to reducing the moisture leaking into the boxes. This is more critical to us as we do not use a plastic insert, and the boxes are a part of the construction and strength of the boat. Thus they are totally sealed at the bottom and will hold water if they leak. We try hard to reduce that as much as we can, and we obviously do not get them all sealed while trying to. We have been involved in upgrading our latch quality going way back, from Sarasota, to the D ring Perko, T handle Perko and then others along the way. We first saw the Southco Latches at a marine trade show. There was no way at that time that we could afford to install them on a bass boat. A competitors increased cost of latches is what allowed us to do that in 2009. Though that competitor was having issues with their design failing, and they could not back up and retain the image of quality without exposing that as a failure in returning to Perko latches on their upper models again. Their use of Southco latches gave us an opportunity to move tot hem on our upper tier as well. We have wanted to ever since we first saw them, though again they were cost prohibitive. To you as a consumer you see a $50 latch, though multiply it by 14 or 15 latches and the cost rises significantly. These are roughly 3 to 4 or perhaps 5 times as expensive as those Perko latches for us to purchase. It becomes a cost of materials and no incremental gain in value for us at retail. Overtons sells the Perko latch for $24.99, whereas West Marine sells it for $42.99. They sell the Teak Isle latch for $89.99. The cheapest we found it on Deal Time was $68.59 through Amazon.com. Here is a link to the Deal Time search ~ Search for Southco. Bass Pro and Cabelas have them for around $62.99 each, though it is not real clear on the matching style. You see, we think we have met in the middle on the $45 price tag? I would like for my 2006 Tahoe to have a radio that accepted an iPod jack also, though that did not start till 2007. So both my other trucks (03 & 06) are without while our 2007 Z71 has the iPod and Media Jack in it. Sorry to have a simile there. Folks still buy other boat brands, as in brands T, St, S or others and latches are latches to them. And the latches on those units are significantly less than the cost of a Perko. It doesnt yet seem that the return is there for the cost of these latches, though 2009 is young yet. In the 90s we began working with Eberhard to develop new latches. They had a fundamental design similar to Southco, though it was all plastic with metal cams. The Volume of latches was needed to produce these latches, and they sought other builders to offer the new latch. When they sought those builder, they insistently asked for a lower price tag. Pressuring Eberhard to the point where they lessened the quality of the latch, and removed the O-Ring set up we had installed for moisture resistance. It seems that a dry box was not a factor to our competition. In the end our competitor took off began working with a friend of theirs to build a new all plastic T handle latch that was cheap, and it is still offered today. We were involved originally in the slam latches of another competitor, though when we tested them they would close and fail to latch. The aluminum transfer bar would impact the aluminum hook and the hook and transfer bar would fail, since they are soft aluminum. This required a bending of the latches and the powder coat would fall off. So we scrapped that concept and it is still used by a competitor today. The development of latches extends to one set of Slam Latches used in a Puma of Phil Addisons a while back. Phil had a trick set Perko T Handle slam latches, which he kept quiet while testing them. Some of you may have seen these, though they did not work out. It seems that the cost of these latches was not accepted by others who Perko offered a concept to. The cost was less than these Southco latches also. We actually built a front deck assembly with lids for Perko. Made several trips going to and from Mountain Home and Miami, FLorida trying to develop these latches. In the end they reduced a solid plastic threaded and molded block to a shell which was too flexible. They changed the arms and actions, failing to increase the stem size and offer a more durable design, in effect to reduce costs at the insistence of our competition. Some of that competition now offers Southco latches too. Had they jumped on our band wagon and accepted the lesser cost, we would have had an even better design last season. Though they were committed at that time to their bar deck design. Phil is welcome to share his uses of those latches. We then designed a flip handle J hook latch that cams also. That latch was in the process of being in R & D when the Southco latches became accepted by a competitor. We have the mechanics of that new latch all formatted to start prior to the Southco move. If we ever have that J cam latch built, it will be a better design. Though it would not retro fit into the existing sockets. A positive for Southco. You see we have taken latches seriously for decades. We have always tried to improve the product here. Though we can and do offer you the latches at a significantly reduced price tag and that is the Christmas offer. They were not available in 2008 from Bass Cat. We have done our best to offer them at well below market value on these latches. Guys we work very hard on Customer Service, as most of you know. The doors being tight is a nature of a Bass Cat for sealing purposes. Please also understand we are trying to offer the best compromise from our side to get you the products you want. This post could be much longer with many more experiences, though we will leave it as it is and we hope that most of you understand. Though we realize that some will not see our position. It is human nature. Thanks you all for your time and your support! Thank you for preferring your Bass Cat boats and all of the comments are welcome. Only through criticism can we improve. Again, we are leaving the previous post up here for all to see. Now you all go have a Joyous Holiday Season! God Bless you and your families, Rick Pierce, Bass Cat BoatsLast edited by Bass Cat Boats on December 24th, 2008, 6:17 pm, edited 1 time in total.
Home Forums Bass Cat Boats Perko and Southco Latches ~ LONG
