Perko Lock Seals
Folks we do stock those small Perko seals and screws to replace the T-Handle seals. If the rubber grommets are not on your T handles, they will leak. The leakage occurs in the lock cylinder and through the key slot. So be sure you press the T handles into the key slots, and check your seals. BCB
Home Forums Bass Cat Faq Archive Perko Lock Seals
