As mentioned above; could be air in the system. Probably need to check for leak/seepage at all connections and at the ends of the hydraulic cylinder at the front of the motor. These will cause air in the system and likely require a trip to the dealer.Also check the attach point where the arm from the cylinder attaches to the motor. That hardware can loosen and cause the problem. Simple fix if that is the cause.C.
