Power Pole One Pump – location of battery cutoff question
I am installing PP One Pump and have a couple of questions. 1. When installing the battery cutoff switch (perko) on the PP One Pump, does the switch have to be downstream from the 60 amp fuse holder, or is ok to add the cutoff before the fuse? 2. Is it ok to remove the 60 amp fuse holder and replace w/ a 60 amp breaker? And if so, any issues using the breaker as both the battery cutoff switch and breaker? Thanks.
Home Forums Bass Cat Boats Power Pole One Pump – location of battery cutoff question
