Prop for 2024 Puma STS / Mercury Pro 250 XS
I have run 4 bladed props on all My Basscat boats for years due to better stability, boat control in rough water.With so many opinions From others I would like to know if the Bravo FS or LT 1 or Fury 24/25 pitch would be the best prop for all around performance. Losing 1-3 mph is not as important to me as having the stability, rough water boat control, Hole shot, and then top end speed. I don’t want to compromise over all boat performance but does anyone have a recommendation on type and pitch that is recommended with all your testing of RPMs, bow lift, stern lift, hole shot and top end speed on the best 4 Blade props, even if it’s one I have not mentioned here. I am sure BCB has done a lot of testing on the best 4 blades prop that gives the best performance on the Puma STS ( it has power poles if that changes the choice) and also if lithium vs traditional batteries would change your recommendation it would be greatly appreciated. Thank You!
Home Forums Bass Cat Boats Prop for 2024 Puma STS / Mercury Pro 250 XS
