Proper method to measure engine height.
      Images added: Measure inside of engine J Bracket to a parallel plane to the lower pad.     Straight line the J Bracket points.     Align the lower pad with a 90 degree line from the pad to the J Bracket.     The engine above is at an engine height of roughly 24" in vertical elevation. The image below shows the bar being held along the plane of the lower pad, and at the lowest point.     …………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………………... Last edited by Bass Cat Boats on 1:29 AM - May 01, 2010, edited 3 times in total.
Home Forums Bass Cat Faq Archive Proper method to measure engine height.
Viewing 15 posts - 1 through 15 (of 18 total)
