TAKFishing wrote:BIGCATTER wrote:Look on the side of the tire , and follow the tire manufacturers recommendation as far as pressure , and run them at maximum .The Deans Stinger is 44 psi rated as well. So when you say run them at max, fill them and measure to 44psi when cold? I assume the pressure goes up when trailering, exceeding 44psi so is this really ok?Yes. Inflate them to the recommended pressure when cold. Properly inflated tires only gain 2-3 lbs. of pressure when in use, or so Ive read, and as evidenced by the tire monitor on my GMC truck.
