Puma Rear Compartment – Adding Drain Holes?
One of the rear deck compartments on my 2007 Puma got water in it when it was uncovered, the lid was not latched and it rained. When the rain stopped, there was ~1.5 inches of water in the compartment. Since there is no drain inside the compartment, I used a siphon hose to remove most of the water, then a sponge to sop up most of the rest. Since then (3 days now), Ive been trying to dry the carpet inside the box by having a fan blow into the open compartment. That is slowly working but looks like another couple of days will be required in order to dry it. Out of curiosity, why are there no drain holes in the corner of the compartment? Will there be any problems if I add them? C.
Home Forums Bass Cat Boats Puma Rear Compartment – Adding Drain Holes?
