the fuse is most likely located inline behind the small panel. pull your foot pedal then remove the small screws holding the panel and gently pull it away from the deck. Fish around or follow the wire into the cap and you should find the fuse holder.Not sure on teh warrenty question. you will need a number 2 square bit for the screwsTreat everyday like it might be the last
