Question about steering
2006 PIV 200 Optimax, hydraulic steering/tilt & trim.I know this was brought up before but would like the answer before taking it/talking to my dealer about it....steering wheel is what I would consider too loose(sloppy) on the shaft (up and down movement of 1/2" or so and side to side of a 1/4" or so). I understand that there may be a knuckle behind steering that can be tightened (theres not any play in the under console part so the loosness is inside of the outer half of the unit). Is this much play normal?Question would also be is this a warantable item by BCB as it may have to be replaced?I will call Scott next week with my serial # to get the scoop but I will be talking to my dealership before hand and would like to hear from you on this issue as to the safety of running it with that much play and any other info you can give..Thanks for the help.Tom(fishfafun)
Home Forums Bass Cat Boats Question about steering
