Sabre XR-6 (150 hp) – Oil Consumption
I'm running a new '06 Sabre with Merc. XR-6. Still on double oil break-in. I had an issue after I bought the boat with the motor not being set up correctly. I blame myself for not going on a test run in 40 degree rain. Anyways the dealer I went to was a good 2 hours away. So I took it to a local premier Merc. shop. They told me the throttle cables were set up incorrectly and that the oil injection system was not bled. I am by no means a mechanic so this is my interpretation of what they said. So I called my dealer and told him this. They said that they definetly took care bleeding those lines. I believe both places as they are both reputable. So now I'm about ready to come off the double oil break-in period. I made a mark on the oil tank for the last two trips. I maybe ran an hour on these two combined and the oil level dropped not quite 3/16 of an inch. Does this sound correct? Could there be a problem that I am unaware of? My biggest fear is going off double oil and blowing it up. The Merc. shop I took it to said that prior to having the set up corrected, that if I wasn't running double oil; I would have blown the motor up. For those buying new boats, don't make the mistake I made. Be sure to take it for a test run. Taking your motor anywhere but the dealer you bought it from will cost you to have it set up, not covered by warranty. Lesson learned. Thanks. Jason
Home Forums Bass Cat Faq Archive Sabre XR-6 (150 hp) – Oil Consumption
