Solid buzz noise
The beep noise that makes the alarm is coming on and staying on when I start the motor. The pad where you insert the key is loose inside and I really think this is the issue. Everything works fine with the motor and I have plenty of oil and have full power. Its almost like the insert in the key pad is loose?? I have never experienced just a straight solid beep noise. When I have engine problems it beeps not a constant noise.
Home Forums Bass Cat Boats Solid buzz noise
