DPT2005 is correct in that the torque tab is not the solution.Lowering the motor or changing the propeller is the answer.Steering wheel torque is a result of surfacing propeller blade. So you need more blade surface in the water, no matter which was you achieve that.Lowering the engine is simple if you have a jackplate. If you do not then a Sabre should be up one hole on the transom for most rigs, and it could be flat. Though if you move it all the way down, a bumper must be added to the left side of the splashwell to prevent the steering from impacting the splashwell on some engines, not all. Seem if you can lower it in 1/4 to 1/2 inch increments. BCB
