Suggestions for loosening nuts/bolts….
Found(2nd time) loose mounting bolts between JP and boat (lower 2 on either side). One so loose I gained about 3 full turns when i re-tightened. Just wondering if mild loosening over time with hydro JPs and bigger motors is normal and I need to check more often or do I need to look at replacing lock nuts or double-nutting??
Home Forums Bass Cat Boats Suggestions for loosening nuts/bolts….
