Yes, hook it to the cranking battery, If you have an opti, if your crank battery is a quality one and at least around 1150 mcas, you should be fine. To prevent parasitic drain and accidental deployment during travel, you should install a battery cut-off switch as well. I put my Talon on the starboard side simply because I did not want to remove the port side “e” ladder.
