My passenger seat is loose again after installing the fix sent by BCB a few years ago. I would like to through bolt the seat this time. My Puma is a 2010 model with the under the seat gas tank. There is an access hatch in the center under the carpeted step box which gives me access to the inner bolt. I would like to create additional access to the outer bolt by installing a similar hatch under the seat.
My question to BCB – is there an integrity issues with the seat pan if I add a 4 inch hatch under the passenger seat? Obviously I will be careful not to drill into the fuel tank.
There appears to be enough space to add a fender washer and lock nut to hold the seat in place. Is there any reason I should not do this?
Thank you.
