Thrust washer failure / Inspection
The thrust washer cracked and seperated in two pieces on my 250 Yamaha. It also let the prop eat into the lower unit housing. Before we go there I didnt hit anything, run a ground, and the prop never left the water. It looked like it had been over heated. Has this happand to anyone else? If the prop nut is loose I would carefuly inspect the thrust washer. ThanksJim
Home Forums Bass Cat Boats Thrust washer failure / Inspection
