torx rubber axle noise
I have a 2010 model with the torx rubber axle so it is a little over 5 years old.Ive not done anything other than change tires.Noticed that there is a slight crackle noise when rolling slowly. Cant hear it from the truck but only if Im sitting in boat while someone is towing me to the ramp. Once it gets rolling (5 mph?) noise goes away.The wheels arent getting hot even after towing a distance - I use a radar temp gun to check. It tows straight and seems fine other than this noise.Is this slight crackle noise at crawl speed normal? Ive heard other trailers make a lot more noise.Should I get the hybrid oil changed?
Home Forums Bass Cat Boats torx rubber axle noise
