trailer bearings
I have a bearing on the back wheel that I noticed some grease leaking down the wheel after loading the boat. Took it to a shop and appeared to only be a little factory grease that was left inside the blue part of the bearing by the insert. (Almost looked like when you grease an insert and dont wipe them off). They put a little grease back in the bearing and it moved the blue indicator out slightly. Today i decided to have the tires rotated and check the rest of the bearings. When they pulled that same wheel off the inside of the bearing by the insert was FULL of grease, like it is leaking it to the outside and the blue indicator was all the way back in where it was before the grease was added (500 miles ago). Anyone have this happen? Time for another bearing? Thanks
Home Forums Bass Cat Boats trailer bearings
Viewing 11 posts - 1 through 11 (of 11 total)
