Trailer Bunk Question(s)
First off, went to load the boat yesterday and no matter what I did it would npt sit right on the trailer. I pulled the boat and trailer out only to find the rear section of the inner port bunk was laying on the rear section of the outer port bunk.... dam. Well no one was waiting for the ramp so no pressure and I could find a work around to get home. I ended up taking a lag bolt from a starboard bunk and with some chunks of ziptie strips jammed in the stripped out holes I mannaged to get the bunk to stay in place so I could load the boat and get home. Now I am looking into what to use to fill the rotted put screw holes and so I can get the lag bolts to hold long enough for me to use the boat this weekend. The expanding polymer plastic of the Gorilla Glue? Maybe fill the void with Liquid Nails adhesive type caulking? I am not sure what will work in the water soaked wood? Any suggestions are welcome. Second part Are there pictures of the actual colors of carpet ? Ash, storm, true grey, and mica.... Or will BCB have the original color on file and so it will match the original? Thanks for you help Dwayne
Home Forums Bass Cat Boats Trailer Bunk Question(s)
