Trailer Lights problem
Hey guys.  Last trip out I decided to check my trailer lights, and they were all messed up.  First off, the right side front fender amber is always acting funny, but it usually comes on after a few miles down the road. Ok, so I turned on the parking lights and all lights were on except that amber, and the right rear brake light was dim.  If I hit the brake, the taillights would not light up, and I think the fenders would get brighter.  If I used the hazards, all the lights would flash.  I tested with 2 diff vehicles with the same result.  I turned the harzards on and wiggled and inspected every piece of wire I could, and couldn't make it change.  Any known areas I should be looking into ??  Does it sound like a ground problem ?  The white wire that screws into what looks like the trailer actuator, is that the ground for the actuator only ?  I plugged a new RR taillight in, and it didn't change. Thanks
2005 Sabre, 150 XR6, Minn Kota Fortrex with Lowrance electronics
Home Forums Bass Cat Faq Archive Trailer Lights problem
