First check and make sure you dont have a burnt fuse. I had a Ford truck that had fuses for the trailer connector and it was separated for turn signals. So check at your trailer plug whether your getting power, than move further back. Once you find the problem, fix it, but better than it was. Always twist your wire tight before crimping. There also connectors that are available that after crimping, you heat it. It shrinks and releases a sealing compound, sealing the wires from moisture. I use those.
