Transom saver – motor mounts
I have always used the lock n stow transom bracket when trailering (against Basscat recommendations). I have had my upper motor mounts break (actually the adapter plate and retainer castings broke) on 250 proxs which Mercury refused to cover under warranty. A friend has had two broken upper mounts- broken just like mine and he also uses the lock n stow. He was told that the broken mounts were due to him not using a traditional transom saver when trailering. Has anyone else experienced this? I was looking at the Lous transom saver, but it seems to support the motor in the same way as the lock n stow.
Home Forums Bass Cat Boats Transom saver – motor mounts
