Trolling Motor interference related question
I have a 2016 Cougar AE. I bought it with dual Hummingbird 788ci HD units on it. I did not have any issues with the original set-up, worked great! I recently replaced the bow unit with a Garmin echoMap 93SV with GT52 Transducer. I have a Motorguide 24V 75 lb. Digital trolling motor. I installed the Garmin unit this passed Friday. I tied in the Garmin unit in the same location as the Hummingbird unit was. I soldered the connections and used shrink wrap over the soldered connections. I also ended up adding another separate ground cable that went from the transducer clamp to the Garmin unit ground wire. When I activate the trolling motor above a setting of one and below 8, I get nothing but interference. I used a multimeter last night and ohmned out between the ground terminat on the trolling motor batteries and the ground on the starter battery. They do NOT share a ground according to my meter - should they? I am just wondering (desperation :-) ) if I dropped a wire off of the trolling motor set-up when I re-connected it to the batteries.Your help would be appreciated!Kevin
Home Forums Bass Cat Boats Trolling Motor interference related question
