trollong motor electrial problem
I just installed a new Motorguide Tour 82lb 24V motor on my 1998 PII.. In current on high mon. High pass or contiant on. after several minutes it shuts off if you keep you foot on the pedal about 10 to 15 seconds it will come back on. If you back it off from hi with the pedal wheel it will keep running but once on full high it happens. I can tell it a bi metal curcit breaker kicking in an out but not sure if it is the boat or if the motor has one internal.. I tried to reproduce at home but without the drag on the prop it does not happen. Any thoughts on how to check before I tear this thing off and take it back then to find out it was not the motor... I removed a Beast 75lb 24v 36v from the boat and never had THIS problem with that one. .. I know I have the new one wired correct and only 24v going to the new motor
Home Forums Bass Cat Faq Archive trollong motor electrial problem
