Vault hubs
After reading a post over on the bbc board got me to thinking. Definitly not wanting to replace all my hubs! Im 6 yrs in on my hubs. My gut tells  me these hubs need tore down and inspected! So my my questions are Can i reuse the cover cap Is the bearing and seals the standard size If standard grease is used will it build enough pressure off to blow the caps off. Or is this just a standard tear down clean and inspect. Repack bearings with wheel bearing grease of choice, replace seals, install exististing vault cover cap. Or is it best to replace with new hubs from bcb Wat is BCB's take on the dexter "ez lube cap". Ive read over on the bbc board where vault and the marine world is basically in shambles. Due to the failure over time. So im it best at 6 yrs in i need to get this taken of. Will bcb carry in parts  a complete grease style hub assembly like the vault assembly. Where its a simply remove one bolt remove the arm and replace
Home Forums Bass Cat Boats Vault hubs
Viewing 15 posts - 1 through 15 (of 17 total)
