Either just punch a screwdriver through the drain hole, or pop the cup holder out. The foam has not been punched below them. This area drains into the net scabbard, and the foam will usually let it pass through. Though in your cases it seems the foam cells are clogging with trash prevetning a drain.
We wanted to be sure there was not an error in construction which someone had changed in error. There is not and phi2ls is right.
Just punch a hole with a screw driver through the foam in the center, and they will then drain.
If you remove the cup holder, then be sure you reset it with silicone to prevent it from blowing out, from the vacuum created while running.
Sorry for the delay, we wanted to check a newer one out to make sure there was not an error.
BCB
