It can be removed from the filter on the engine. Check you Owners Manual to see where the removal is on your engine. Some have separate canisters, and others have a filter screen on the pump with a red knob. You can run additive in the engine, though we suspect it is a combination of old water and new in the fuel. The ethanol blends add to this. If there is a good bit, then you may have to drain it.
